ok, lets say your application would normally require 350cc injectors
what happens if you put in 440cc injectors?
it will just run the injectors at less than full load right?
like if you have a stock ecu, lets say a P13 on an H22, and you should have 350cc saturated, but instead you have 440cc, will you run too rich or will the ecu get the o2 value and tell the injector to tone it down?
