hit curb drivin at night -> funny noise
Discussion in 'Wheels / Suspension / Tires / Brakes' started by cxnsi, Feb 1, 2005.
  1. cxnsi
    cxnsi Junior Member
    :blink: hit the curb while driving at night. left driver side makes a clanking sound when driving on bad roads
    or turn steering wheel to the max degree. what could be wrong with it? i havent had time to bring it out to the shop. thanks
  2. UDT
    UDT Senior Member
    california
    you gota inspect theres to much that could clunk to say.
  3. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    is the rim bent? busted tie rod? all those things you can look for
  4. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    Check the upper and lower control arms too
  5. reckedracing
    reckedracing TTIWWOP VIP
    NY
    hit = slammed into? or drove over?
  6. hybrid89
    hybrid89 thistownsucks...
    SoCal
  7. One Stop Customs
    One Stop Customs Senior Member
    Los Angeles
    OUCH!!! well... Just look underneath... It will be a tie rod most likely...
  8. cxnsi
    cxnsi Junior Member
    . the cv joint made some shaking noise when i shook it. so i think it is the bad cv joint. how do i get this fixed? what about the cost? take this to a body shop or a balancer?
  9. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    just go to autozone and buy a new axle for that side, the price is not bad and there is a core charge when u return your busted one, also these axles are lifetime warantee, so if it happens again u get another for free.
