hmm..
ultiima
Originally posted by DelSlo@Mar 20 2005, 10:17 PM
word. you got spark, now do you have fuel??
and unless your timing on your cam and crank are off it should start with the dizzy in almost any position!
id be checkin for fuel pressure as well as if your injectors are firing.
[post=476270]Quoted post[/post]​
i now got spark and fuel but it wont start, im also sure i got compression......the timing may be a tooth off,but shouldent it start anyways,and run bad? Or is 1 or 2 tooth off big enough error so the motor wont start? tried also and spray some startbooster in the tb... and the hole shit cought on fire... lol (sorry if my english is bad im Norwegian...hehe)
Double and triple check your timing, mine was off when I did my first swap, and it took three hours to track it down. Also check all you grounds, and make sure you battery is full.
