honda ecu help
Discussion in 'ECU's, Electronics, and Tuning' started by keg, Jan 3, 2010.
  1. keg
    keg New Member
    I have a ek civic with a d13b engine im wanting to switch to obd1 ecu so i got a swap harness but my ecu only has 2 plugs comming out of it, so the harness doesnt work the code is 37820-p2a-003 can any1 help?
  2. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    If you put an OBD1 harness in the vehicle, you need a standard OBD1 ECU to use.
  3. keg
    keg New Member
    its a obd2 harness in car i want to run 0bd1 ecu have swap harness but my ecu is different to normall obd2?
  4. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    Perhaps post some pictures. I'm not sure what you have, so I can't make any suggestions.
  5. FREAKBOY
    FREAKBOY New Member
    Cottingham EROY
    I've seen these 2 plug ECU's before in the Capa and Jazz.
