Hondata S200
Discussion in 'ECU's, Electronics, and Tuning' started by Luke18, Jul 11, 2005.
  1. Luke18
    Luke18 Junior Member
    I am currently building the bottom end of my OBD2 GSR. I will be buying a Hondata S200 w/ Boost. I wanted to know what is everything that I will be needing, besides bigger injectors, to purchase so I am able to you the Hondata S200 with my OBD2 GSR.
  2. pissedoffsol
    obd2-1 conversion harness... obd1 p72 ecu socketed and installed the data logging port. switch the iab activation to work with obd1 (documented int he artciles/swap forum)
