Hood isn't fitting HELP
Discussion in 'Civic and del Sol - EG and EK' started by Da1nonly0015, Jan 13, 2007.
  1. Da1nonly0015
    Da1nonly0015 New Member
    I have a del sol with a ls vtec and I just bought a VIS evo hood. My problem is the hood will not close because of the valve cover. The motor sticks up to high. I am trying to rule out the fact of cutting the crap out of a $600 hood if possible. If I switched my motor mounts from integra to civic Si or something else would that possible lower my motor by about half an inch or is this possible. I have seen plenty of other sol's with GSR/ LS Vtec with after market hoods and thay fit fine, So why the hell isn't mine fitting. Any sugestions or answers would be great. If you have the same swap or a GSR swap, what mounts did you guys use? and do you have aftermarket hoods?
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    did it close with the stock hood?
  3. Da1nonly0015
    I never actually had a stock hood, I bought it with a OEM Cf hood, It did close and didn't look like it was hitting on anything but it was bowed up some on the driver side (same side I am having troubles now) I bought a Invader hood and it hit on the valve cover, notched and shaved it and still didn't fit, I think it was Screwed up from the mold (damn fiberglass products) so I got rid of it and now have the VIS EVO and damnit is is a sweet hood and I am going to MAKE it fit one way or another.
  4. 801CRX
    801CRX Got Rice?
    UTAH
    well it looks like you have to shave it
  5. DelSlow89
    DelSlow89 93 Del Sol
    I live in Portsmouth, VA
    I have the same problem. I just did an engine swap from the d15 non vtec to a d15 vtec. the hood closed fine when the stock motor was in their. When i get in it (gas) the hood like to pop itself just as if you pulled the release button. I dont know if the motor is actually hitting te hood when the rpms raise from the movement but i think i might need to change the mounts or shave the inside of the hood around the valve cover.
