How could this be possible?
Discussion in 'General Tech and Maintenance' started by Shock_whore, Jul 6, 2007.
  1. Shock_whore
    Shock_whore New Member
    Before 2nd O2 sensor and stock air box installed: (had a short ram intake)
    Failed HC 1.4 >>>>> limit .6
    Failed CO 16.8>>>>>limit 10.00
    Passed NOx 1.03 >>>limit 1.5
    After 2nd O2 sensor+stock airbox installed: (bastards won't test my car cuz of the short ram intake)
    Failed HC 1.3
    Failed CO 13.55
    Failed NOx 2.08
    HC and CO seem to dropped a bit, but NOx almost doubled.
    Did research and the cause of failure for HC + CO is most likely because the car is running too RICH. Too advanced of a timing and ignition related.
    NOx = High combustion temperature + running too LEAN
    How could this be? Running too RICH + too LEAN @ the same time isn't possible... CAT should be working fine. Got it put in a couple months ago.
    Anyone know where the EGR valve is located on a B16a2? Thanks!
