How do I read code?? CEL Check Engine
Gooseguir
Member
I put a b16 sirII in my 92 civic and I've had a CEL the whole time I've been driving it, for like a month now, I just put in a knock sensor and that still didn't help. So I was wondering if anyone knows how to read codes that would be great. Then I can finally figure out exactly what the problem is. My engine has been running in "safe mode" and I'm tired of it, any help will be greatly appreciated. I have a 92 cx and I think that the 02 sensor may be hooked up wrong. Maybe thats the problem I don't know. I just need to read the code, thanks
Do a search, this has been posted a few times with pics of the connector you need to jump. But basically you jump the service connector (under glovebox on passengerside wall, above floor board), then you turn the key to ascessory, and count the blink of the CEL, then you have the code, look it up, and get the info.
