how do i tighten a head onto the block
Discussion in 'General Tech and Maintenance' started by phengnhou, Mar 10, 2005.
  1. phengnhou
    phengnhou Member
    hello everything i just need a little help. right now im doing a zc sohc swap in my civic hatch. first i need to know if that motor is even good. or how much power i'll pull out of that motor. it'll help me if you know the specs of the motor.
    but right now i have the head apart from the bottom block and i need help on how to torch the head onto the block. if somebody can help me out by telling me how man turns i need to turn the screws.
    ok thanks so much for helping.
    pheng
  2. lowandslow
    lowandslow Senior Member
    maine
    block>gasket>head>head bolts/studs...if they need to be torqued find the specs on how much, get a torque wrench and get it done. just listen for the click. too easy
    maybe put some threadlock on the head bolts/studs, probably couldnt hurt
  3. VTEC_CBR
    VTEC_CBR Senior Member
    Virginia Beach
    hazha i read that literally, torch, like fire, anyway, yeah, and well honestly for me it's been quite a while since i have torqued a head down, but correct me if i am wrong, but shouldn't he torque the bolts halfway first, starting with the bolts in the center moving outward?
  4. CRX-YEM
    Wallingford, CT
    that's what I've always thought and done as well.
  5. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    something like 22 lbs first, and then the final Tq down after that; what ever the Tq should be.
  6. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    yeah, if i'm not mistaken. you go to 26 lbs. first, then finish off at 61lbs. in this squence:
    9 3 1 5 7
    8 6 2 4 10
    or something similar...as long as you go inside to outside.
  7. reckedracing
    reckedracing TTIWWOP VIP
    NY
    how many turns?!?!?!!
    screws?!?!?
    wtf
    lmao
    dude, check autozone.com
    look in their repair info for a 92-95 civic ex with the sohc vtec engine...
    that should give you the proper install procedure for the head bolt orders and torque specs...
    and that should net 130 hp
  8. reckedracing
    NY
    Now tighten the cylinder head bolts in the proper sequence in two steps:
    1st step: initially tighten to 22 ft. lbs. (30 Nm)
    2nd step for D16Z6,D15Z1 engines: fully tighten to 53 ft. lbs (73 Nm), or
    2nd step for D15B7, D15B8 engines: fully tighten to 47 ft. lbs. (65 Nm)
  9. lowandslow
    maine
    ^ damn thats some good info
  10. 92CHB
    92CHB Senior Member
    Easthampton, MA
    X2 :thumbsup:
  11. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    naw just use some glue
    but seriously, make sure your torque wrench is well calibrated for something as important as this. We rented one from auto zone and it was way off compaired to the electornic snap on.
  12. UDT
    UDT Senior Member
    california
    You mother fuckers need to go buy the fuckin books for you cars. Even if only for having all the Tq specs infront of you when working.
  13. CRX-YEM
    Wallingford, CT
    man I was looking all over the net the other night for picture of something like that
    they would of been from a chevy 350, but none the less the same principle
  14. reckedracing
    NY
    autozone.com guys...
    i fully back helms manuals all the way, but if you're in a bind and need sequences, general directions, hints, or torque specs check out autozone...
    very good site for a rush...
    they have wire diagrams, all motor torque specs, just about anything you could need when doing a job that you don't own a helms for...
    they have saved my ass a numbers of times...
  15. UDT
    UDT Senior Member
    california
    W3rd on that , me to.
