How do you lower compression
Discussion in 'Engine Building' started by 1Twin1, Aug 12, 2006.
  1. 1Twin1
    1Twin1 Junior Member
    ok heres the deal i have a 89 crx with a b16 swap with a toda stroker kit in it. i have put the motor up to 1797cc's with a compression ratio at 11.0:1. i orignanally wanted to go n/a and now i want to boost it with a turbo for more power but i dont know how to lower compression plz give advice
  2. GSRCRXsi
    MD
    thicker head gasket, lower compression pistons
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    I would go lower compression pistons. Those Todas are very nice pistons, but not great for boost.
  4. Taco15
    Tallahassee Fl
    what headgasket are you using? 1 layer? 2 or 3 layer. I have a new felpro 3 layer if you want it. Dont for get that Toda sells thicker headgaskets for people who want to lower comp. i'll sell my Felpro 3 layer for 45 shipped
  5. 97CTR
    97CTR Senior Member
    dude if you are are trying to sell a headgasket atleast tell him what thickness it is. Three layer tells him nothing.
    Bottom line is if you want to keep your pistons then you will need a thicker headgasket.
  6. Taco15
    Tallahassee Fl
    you know.......if i new i would definitly have told him. why do think I asked him what layer headgasket he has? Unless he gets something aftermarket like toda,cometic, etc. the felpro 3 layer is the thickest. correct me if i'm wrong
  7. 1Twin1
    well what size head gasket should i get???
  8. Taco15
    Tallahassee Fl
    i'm guessing you dont know what HG you have on now since you havent torn the motor apart.:huh: If it was me i would tear the head and see what i have. If its a 1 layer then you good. That way you can find the thickest. The only place i know that offers thicker headgasket that state the compression is TODA. but then again i know there more companies.
