How Many Wires?
saturn_boy96
88 C1V1C 53D4N DR1V3R
ok i have adistributor from an obd2 civic si. i need to know how many wires should be on the plug, and i need their colors. mine has a toal of nine wires, but i have been told it should have one more or one less, who's right?
i have a second question, too. are the plugs (colors or wires) different between vtec(b16a) and non-vtec(b18b) dist.?
1- All OBD2 dizzy's have the same amount of wires (SOHC-SOHC, DOHC-DOHC)
You cannot use a SOHC dizzy on a DOHC engine and vice-versa.
2- They shouldn't be. You can use a LS dizzy on a B16 as long as you cut one of the legs off.
so how many wires on an obd2a distributor?
what does it mean to cut off one of the legs?
ok now that i see the difference(mow i have an ls dizzy and a b16 dizzy) i know what you mean, but the wires are exactly the same.
for some reason when you get to obd2b they change.
