How much boost?
Discussion in 'Forced Induction' started by import_racer, Oct 28, 2002.
  1. import_racer
    import_racer Member
    How much boost can you run with a stock second gen B16 without any internal mods? If you need to modify the engine, what would be reommended on a limited budget? Thanks.
  2. 98integrals
    98integrals Senior Member
    Kzoo
    ive seen people run 8psi. but that was only a 15.1 1/4 et with a good driver.... maybe it wasnt 8.. i dunno
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    AHHHHHHHH! It all depends on what turbo you plan on useing! The CFM's on every turbo are different! 8 psi on a small turbo would be fine, but on larger applications you will blow you headgasket right out on 5psi! Please be more specific...
  4. import_racer
    import_racer Member
    I have a rev hard stage 2
  5. pissedoffsol
    intercooled? 8-10.
    non IC'ed, 6-8
    and is it TUNED? if you only have an FMU, you aren't tuned.
    that would be my safe guess. im sure you could run more, but if you arent tuned by hondata, dont go higher than that
