How to adjust IDLE on 00 GSR??
IIpower
Hello I was wondering as to how to adjust the idle on a 00 GSR. Ive tried using the idle control adjustment the one that you use with a flathead rite on the throttle body. But the idle didnt move one bit. I even took the whole idle adjustment screw out and the idle didnt rise or nothing. Reason I want to adjust my idle is because rite now its diling at around 650-700rpm and at about almost 600 with the AC on. Is there any ither way to adjust my idle?
Very important: Y isnt my Idle adjustment screw working (the one that is used with a flat head and rite above the throttle body)? loosen and tighten it and the RPM stays the same?
thanx for the response. I tried that the cable is where ti should be and its not to tite or nething.
