How to by pass the 16p security connector?
Discussion in 'Car Audio / Security / Electronic Accessories' started by doug810, Aug 10, 2005.
  1. doug810
    doug810 Junior Member
    I have a 1997 Civic EX and I just installed a new deck. The problem is that the keyless entry wont work. I was wondering if anyone out here knows how to bypass that harness to make the keyless entry work?
  2. drpenguin
    drpenguin Senior Member
    Salem, Or
    you installed a new radio? and now your keyless entry dont work? do you know if you chopped anything that you were not supposed to?
  3. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    The keyless entry is integrated through the radio. Ive seen people install the radios in the trunk, just to save keyless entry.
  4. doug810
    Is there a harness that can be plugged in to re-route the circuitry. Or does anyone have a how to splice which wires and connect?
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    Fresh off the Crutchfield Sight:
    Connections:
    Note: In order to retain your factory keyless entry functionality, you'll need to keep your factory radio, and relocate it inside your dash behind the lower trim panel. This harness has two plugs - one connects to the factory wiring, and the second plugs into the factory radio to provide power to it. If you remove the factory radio, you will lose your factory keyless entry feature.
    12V constant power
    12V switched power
    chassis ground
    power antenna turn-on
    dimmer
    left front speaker +/-
    right front speaker +/-
    left rear speaker +/-
    right rear speaker +/-
    Thats pretty friggin ghetto, but I suppose it has to be done.
    The link to the "harness" that they are referring to.-----> HERE <-----
  6. macadoshes1
    macadoshes1 Junior Member
    Scosche Makes a relocation kit for the factory radio to be put into the trunk. If you dont want to do that then yes you do have to smash it into the dash under the aftermarket radio. It Fits
  7. doug810
    Thanks for all the help!!! but that is pretty :ghey: that i have to do that though. :angry: but i guess thats what i have to do next. I still have to convert my 97 front to the 99-00.
  8. neonmike
    neonmike Senior Member VIP
    could be worse you could have a gm car that needs the factory radio to retain the use of the airbags among other critical things for your car.
  9. drpenguin
    Salem, Or
    Dude all thats homo. thank god my rex isnt like that. just go with a aftermarket keyless yo
  10. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
    just put it in your glovebox....thats what i did using the cruthfield harness. its really not that big of a deal lol.
  11. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    and what car is that?
    cause last time i cheacked the air bag systemis a seperate self contaned sytem
  12. neonmike
    that would be almost any gm car from 2000 up. cavalier, sunfire, trailblazer, envoy, corvette......... i can keep going with the list if you would like me to.
