How to install JDM 4 lug suspension on an EK??
Discussion in 'Wheels / Suspension / Tires / Brakes' started by sheekdude, Sep 4, 2005.
  1. sheekdude
    sheekdude Member
    Hempstead, NY
    I just bought 97 itr 4 lug suspension and i want to put it on my ek, but i know the ek's control arms are different to itr's so what do i do??? Is there a way for the ek's contol arms to fit the itr spindles??? Help, please???
  2. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    Um...unless you mis-worded it, ITR's have 5 lug hubs. That's why you would buy them. As for the control arm problem, which ones are they?
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Survey says....wrong. 96-97 had four lug 4x114.3 :)
    Just unbolt the spindles/hubs from the ITR trailing arm, and bolt them to your Civics trailing arms. There's four torx bolts, and one big one, forget the exact size. You're going to need the cables and brakelines for disc though.
  4. hosmer
    B R I D G E W A T E R
    nevermind...
  5. sheekdude
    sheekdude Member
    Hempstead, NY
    Thanks a lot. I'll try that!!! I wasn't sure if the the torx bolt pattern was the same as the usdm 4x100. I'll let you know how it turns out next week.
