how to play/open bin, cue, and iso files
Discussion in 'Computers, Games, Electronics etc' started by pissedoffsol, Mar 21, 2006.
  1. pissedoffsol
    I was just asked how to do such a thing, so i figure i'll post it here for everyone else to see too.
    First and foremost, there's 100's of tools and 100's of ways to do this. I simply like this method and use it. You may use your other tools if you wish, or mount it to a deamon drive.... whatever. you're smart and don't need this post :)
    brief quote:
    bin is a binary image similar to an iso file, which is an IMAGE of a cd. it uses the same concept of norton Ghost in a sense, as its not the actual data-- its a picture OF the data.
    a cue sheet is simply a table of contents. think of a DJ booth with a cue button... he cues to track 4 :p
    go download isobuster:
    http://www.isobuster.com/
    after you install it, there will be a shortcut installed in the send to menu of the right click mouse key.
    right click on the cue file -> send to -> iso buster
    it will open up as session 1 or someshit depending on the file. there will be sub-files underit, but we want the whole thing, so make sure yo're minimized on the tree and showing +Session1, unexpaned (as opposed to:
    -Session1
    ...blah1
    ...blah2
    right click, and extract with the mpg option, since this is a video.
    this will give you two mpg files. the first one is probably blank... simply delete it.
    do that for both discs... now you got your 2 mpgs that you can create your vcd with using nero or adaptec if it supports it. (i dont use it so i dont know how it works in that program.)
    iso's work the same way--- they need to be busted out :)
  2. TommyTheCat
    TommyTheCat Gonzo Scientist
    Minneapolis, MN
    DL VLC player -> watch bin file. Enjoy.
  3. Drake
    Drake Well-Known Member VIP
    Good write up B. I was actually going to do this very same write up tonight because my buddy was having problems with Bin/Cues. Mine was going to be geared more toward what Tommy is talking about, using VLC to watch them.
  4. GSRCRXsi
    MD
    i use alcohol 120% and you can either emulate a drive, and open the image with it, or you can actually burn he image to a CD/DVD with it. you can do the same with Deamon tools i think but alcohol is more user friendly
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Deamon Tools doesn't burn, but the concept for watching is the same. You can always open it, and install from there too, or save and burn with something else.
  6. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    Man that is way too many steps, get a mac and double click on the file. :p
  7. phunky.buddha
    Dallas / Fort Worth, TX
    No way dude... way too complex B. Just download the latest copy of CDRWin, then install and burn.
  8. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Better than a Mac, install Linux and mount -o loop /dir file.iso
  9. CRX-YEM
    Wallingford, CT
    :concur:
  10. pissedoffsol
    yeah, cuz i'm going to install a new OS to play a movie or something I DL'ed.....
  11. lsvtec
    It's a bigger philisophical issue, you can move to an OS where you are not restircted on how you use anything or you can let the Gates/Ballmer Beast of Death continue to tell you when to piss... :)
  12. pissedoffsol
    and its completely off-topic for this thread.
  13. phunky.buddha
  14. thepowerofdonuts
    thepowerofdonuts New Member
    Someone already said this, but you can download VLC Player from videolan.org and just watch it as is.
  15. matthias82
    matthias82 New Member
    gives the error
    "/dir: is a directory"
    (btw: in my case I want so watch bin/cue, dont know if that works the same?)
    Well, I have no sound if I just open the bin file from VLC
