HatchSpeeD
...Hi...
I was wondering if anyone can point me to a write up or has any info about how to replace a lower ball joint boot, specifically for a 2000 civic?
I replaced an axle over the summer & inadvertently broke the boot. The ball joint is still fine & has no play but I wanted to get this done before the winter.
Please include tools & pics are a plus if possible.
My assumption is to take off some sort of clip that must be holding on the boot, install new boot & add grease. If that is the way to do it, what tool do you need to take off the clip? How do you add the grease?
My fear is that you need to take out the balljoint in order to replace the boot...
If so, I'd might as well replace the balljoint which is what I'm trying to avoid...
