How to tell if Vtec engages?
Discussion in 'HYBRID -> ED-EF / DA' started by autox 89 dx, Sep 23, 2008.
  1. autox 89 dx
    autox 89 dx Member
    SF bay area
    I finished my SOHC ZC with Z6 head swap about two weeks ago and the car runs great, but how can I tell if the v-tec is working?Also what is the rpm that should engage?
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you should here or feel it...
    i dont know exactly but it should be around 4400rpm
    you can hook up an led to the switch that tells you when your in vtec.just splice the positive into the vtec switch wire and run the negative to a ground
  3. JDMB20Coupe
    JDMB20Coupe Powerd With 1 Cam
    Chester, VA
    what color is the vtec wire on a stock harness is it blue?
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    the one coming from the oil switch
  5. JDMB20Coupe
    Chester, VA
    is that with the 2 wires or one?
  6. haao13
    haao13 New Member
    PA
    which one? from the solenoid or pressure switch?
  7. TurboMirage
    dude you should know when vtec engages... your car should double in power. if not its messed up!
  8. TurboMirage
  9. eg6sir
    not on a single cam.. its hardly noticeable
  10. JDMB20Coupe
    Chester, VA
    theres 2 plug one is in the solenoid one is below it which one is he tapping into?
  11. Matts96HB
    Matts96HB . Moderator VIP
    DOUBLE the power and DOUBLE the posts! lol jk jk
    But anyway, yeah like eg6 said its going to be hard to tell with a single cam. Damn near impossible if you ask me.
  12. prpprimo
    prpprimo Hondaholic
    ABQ
    Lower speeds it's noticeable. Like INJEN said, you will hear it. Especially with a performance intake. I know mine is loud as shit.
    and uh..shit is loud. ^_^
  13. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    True, on my girlfriends R18 it activates so subtly that your cant tell, engine just gets gently more grunty. I know its i-VTEC but still. If you have a cold air intake and/or exhaust you would no doubt be able to hear it alone.
  14. squeals
    squeals New Member
    Charlotte, NC
    yeah, i have a stock DX hatch. no vtec for me...........it's sad im a honda enthusiast without vtec
  15. INJEN78
    INJEN78 HS LEGEND
    OHIO
    minime time?!?and even on a single there should be a noise change or a little power change,,something
  16. JDMB20Coupe
    Chester, VA
    yea i can hear mine but the wierd thing is everything ive read about my ecu says it comes on at 5500 but when i hookd up th light like you said it comes on at like 4400am i nuts or are the things ive read wrong?
  17. 94H_Ex
    94H_Ex Under employed
    Florida
    i have two vtec heads for sale. ones a Z6 head, the others a Z1. so. either or. gas mileage, or more power. :cool:
  18. LS_ integra_delsol
    LS_ integra_delsol New Member
    sonora CA.
    no every sohc vtec motor ive had kicked in about 5600-5800, but yeah you should be able to hear it or feel it just listen closely because sohc motors dont tend to hit vtec like the dohc ones do if the head is stock
  19. autox 89 dx
    autox 89 dx Member
    SF bay area
    Well it does rev a little bit faster but its not really noticable all the time but the car is way faster than before. I wasn't sure if it was working or not.Should I get the car tuned? its a ZC with a Z6 head.I have the typical I/H/E ,AEM cam gear, B&M command flow, MSD 6A external blaster coil with MSD cap rotor & plug wires.
  20. haao13
    haao13 New Member
    PA
    if it wasnt engaging wouldnt it only rev to like 5k and throw a code?
