how to wire vtec plz help.........
Discussion in 'Accord' started by turbohonda08, Mar 13, 2008.
  1. turbohonda08
    turbohonda08 New Member
    i have a f22b2 block and the head tha twas on it was non-vtec but the wiring harness have the vtec high pressure sensor plug on it so i'm guessing the car was vtec and someone made it non-vtec how do i hook up the the vtec silinoid it has one wire green with a white line???????????
  2. BrutalB83
    Rochester Hills, MI
    I'm confused here...
    So the block says F22B2? That's the non-VTEC motor. What does the valve cover look like? If the valve cover doesn't say VTEC on it, than the head is stock F22B2, and you're not going to have VTEC, no matter what you wire up...
  3. turbohonda08
    no the block is f22b2 but i did a head swap from non vtech to vtech i have the high pressure switch and silinoid but i do not know how to wire it have the the poa ecu and all just need help with wiring
  4. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    What is vtech? What is a silinoid? And most of all, wtf is a poa ecu? You should let a professional do the wiring being you can hardly spell correctly.
  5. monotech909
    monotech909 Got V-tec?
    Inland Empire
    take it to nearest performance shop and ask them if you have a v-tec solenoid better yet if you have v-tec engine. Just cause you have a v-tec solenoid wire hanging off your harness doesn't mean you have v-tec.
  6. fonztheman
    fonztheman New Member
    that wire might not even be a vtec wire it might be a temp wire i ran into that problem with my motor there is 2 temp sensors and 1 vtec so there are 3 connectors that are the same
