HUGE List of parts i need gone asap ....CHEAP
Discussion in 'Parts: For Sale/Trade/Wanted' started by Fibercation.com, Nov 29, 2007.
  1. Fibercation.com
    Fibercation.com Banned
    Ohio
    GSR 94 teg parts>
    Edlebrock 65 mm tb $250 Shipped!! http://columbus.craigslist.org/pts/456833653.html
    Premium gsr turbo flange $50 Shipped!! http://www.bmcrace.com/product...id=81
    All Black parts>
    i have quite a few black door panels..im for more info
    $40 ac mount
    $20 upper aluminum dr's mount
    $150 shipped Full OEM gsr headgasket and mani set
    $110 shipped p72 gsr virgin ecu
    $50 shipped gsr slight polish valve cover http://columbus.craigslist.org/pts/490471242.html
    $35 shipped gsr ac compressor
    $35 shipped gsr ac condensor
    $15 shipped each gsr pwr steering brackets
    $15 shipped speedo bezel x's 2
    $10 shipped pass side door handle/lock bezel x's 2
    $15 shipped E brake handle
    $55 shipped CF gas lid
    $55 Carbon Fiber shifter surround
    $115 Shipped upper and lower steering column parts (clamshell) in Carbon Fiber
    $35 Shipped moonroof switch/vent x's 3
    $10 shipped each rear speeker grill x's 2
    $50 moon roof assembly Not shipping unless your giveing me like $200
    $30 front sway bar
    $30 rear sway bar
    $15 shipped rear dome light
    $40 shipped clutch slave and pedal
    $65 shipped gsr mc/booster
    $60 shipped each airbag x's 2 sets
    $30 bux each bare dash...have 3
    $25 shipped under steering wheel plastic part x's 2
    $55 shipped 98 ls cluster
    $70 shipped gsr cluster
    $40 shipped master window switch
    $35 shipped dr's headlight (94-97) same on pass side
    $90 upper radiator support cut off x's 2
    $30 front crash bar x's 2
    $35 shipped rear hatch struts
    $50 shipped rear blk cargo cover/tray
    $35 shipped on the abs unit x's 2
    $50 steering column/$150 with wheel and airbag
    $50 each airbag (have two full sets in blk)
    $20 shipped srs unit with wires
    $30 each bare blk dash...some wear not shipping
    $35 stock gsr intake
    $40 shipped each tail lightw/harness $60 shipped for both http://columbus.craigslist.org/pts/436850083.html
    $20 shipped 98+ brand new black turnsignals
    $50 FIRM each Both WHITE doors mint with windows
    $50 FIRM one Red pass door Mint with glass
    $35 RED rear filler part under tail lights...has gsr badge Pics> http://columbus.craigslist.org/pts/442397806.html
    $150 Rear red hatch with spoiler/ glass
    $30 Pass red Fender MINT
    D SERIES PARTS>
    D16z6 swap> unknown milage...Does run ( have a video)
    no clutch left in it...comes complete minus harness and p28
    $400 bux....$300 if you dont want the tranny
    LOCAL PICK UP ONLY Located in columbus ohio
    $15 shipped each 2 d15b7 maps
    $20 shipped Z6 map
    $25 shipped z6 iac
    $25 shipped z6 starter
    $30 shipped T brackets
    $90 Good head 90k miles $120 shipped Pics>
    http://columbus.craigslist.org/pts/455342325.html
    $25 eg seat rails
    $10 each motor mount (have a box full)
    $65 distributer or $70 shipped
    $110 shipped z6 engine harness uncut
    $100 head and block UNKNOWN condition pickup only
    $25 z6 oil pan or $35 shipped
    $20 bare intake mani or $35 shipped.
    $175 shipped Full AC for 92-95 civic
    $30 shipped no name upper header
    $30 stock intake
    $25 shipped each i have 3 tb's 2 look like from z6...other is slightly larger im guessing y8
    $55 shipped y8 distributer
    all are d series.
    $40 shipped eg mudflaps http://columbus.craigslist.org/pts/451726702.html
    $80 shipped this has the higher red line......not just the tach
    lmk what milage you want it rolled to
    $70 shipped a non si speedo with tach,both are 5 speeds
    $25 shipped ex door tweeters
    $10 shipped dock lock switch
    $100 shipped black/grey pwr ex door panels
    $50 eg core support cut
    $55 set of eg healights and corners shipped
    $150 Red stripe del sol seats in good condition Pick up only
    Prices include shipping if it says "shipped" otherwise its + shipping or pickup only
    if there is a " x's 2 " after the parts i have two of them or two sets
    Located in columbus, ohio Large items like the full motor or body parts i WILL NOT SHIP if its small and you want to pick up the "shipped" price becomes cheaper
  2. Fibercation.com
    Ohio
    bump
  3. Fibercation.com
    Ohio
  4. Fibercation.com
    Ohio
    Will trade for H22 stuff
  5. Fibercation.com
    Ohio
  6. Fibercation.com
    Ohio
  7. igotnothin
    igotnothin New Member
    harford co MD
    i need a driver side 96- 2000 d16y8 or equivalant engine mount. if ya got it hit me up plz
  8. Fibercation.com
    Ohio
  9. Fibercation.com
    Ohio
  10. Fibercation.com
    Ohio
    Bump cause im your mother's pimp
  11. Fibercation.com
    Ohio
  12. Fibercation.com
    Ohio
  13. ghsbaseball91
    ghsbaseball91 New Member
    Catawba, Virginia
    will the sway bars just fit the gsr?
  14. goldgreen90ef
    goldgreen90ef goldgeen90ef
    cold ohio
    still got the z6 dizzy? do you use paypal?? thanks
  15. Fibercation.com
    Ohio
    yea teh sway bars are off a gsr/ls
    yes i have the z6 disty....pm for info
  16. JDM92Lude
    JDM92Lude Banned
    Mechanicsburg, PA
    i got h-series parts, and i want your p72 and possibly the throttle body
  17. Fibercation.com
    Ohio
    What h22 stuff do u have? i sold teh ecu
