CA huge partout!!!! race ready ek hatch shell,2 built motors,turbo kit and much more!!!!
Discussion in 'Parts: For Sale/Trade/Wanted' started by b18vtecrx, Jul 16, 2012.
  1. b18vtecrx
    b18vtecrx Senior Member
    well to make this simple, i bought all this from traction issuez on here, and im just looking to part it out, i have driven the car and it makes it much more difficult for me to part it, but i only bought it to part it out. i have to say everything was built right. anyhow i'll try to get a complete list together by the weekend with pics but for now i want to get the main things listed, here we go:
    IF YOUR INTERESTED IN SOMETHING OR WANT ME TO TEXT PICS SOONER THAN SUNDAY PLEASE TEXT ME AT 707-540-4272 thanks -mike
    IM LOCATED IN NORTHERN CALIFORNIA ABOUT 40 MINUTES NORTH OF SF, MY ZIP CODE IS 94928.
    I AM WAITING TO USE MY BROTHERS CAMERA I'LL HAVE TONS OF PICS POSTED SUNDAY 7/15/12 IN THE MEANWHILE I CAN TEXT LOWER QUALITY PICS TO THOSE INTERESTED.
    KEEP IN MIND ALMOST EVERYTHING HAS EXTREMELY LOW MILES ON IT...
    97' ek hatch w/ 00' front end rolling shell(salvaged title) with full cage, race seats,rear disc brakes,koni yellow shocks,stainless braided brake lines,battery kill switch wired in,fuel tank is sumped,still registered until dec. ASKING 1700 obo there's more that can be negotiated to be sold with the car for a bit more such as the sir cluster,full stainless braided fuel lines,SX fuel pump, ITR brakes with extended studs,traction bars. there may be more i'm forgetting as i only got this car yesterday 7/11/12.
    built motor #1(this motor is running in the car now)
    LS-VTEC(b18b block w/ B16 ported head)
    GE sleeved
    JE pistons
    crower rods
    ferrea valves,ferrea dual valve springs and retainers
    ITR cams
    ARP studs
    AEM cam gears
    JG intake manifold
    valve cover is setup for catch can setup(could negotiate catch can w/ lines,1200cc injectors and AEM fuel rail into deal.
    this motor was dyno'd by DSR putting down 580HP.
    asking-3,000 obo
    built motor #2(engine has been broken in with 300 miles on it been sitting on a stand every since then)
    GSR block
    CP pistons
    eagle rods
    ferrea valves,ferrea dual valve springs with supertech retainers
    CTR cams
    ARP studs
    STR cam gears
    JG intake manifold
    ASKING-2500 obo
    GSR transmission rebuilt w/ quaife LSD
    ASKING-1500 obo
    turbo kit-(also running in the car now everything works great)
    precision 6262 turbo with v-band down pipe
    oil feed and drain lines
    intercooler
    HKS wastegate with dumptube
    custom tubular turbo manifold
    all mandrel bent intercooler piping with couplers and T-bolt clamps
    HKS Blow off valve
    ASKING-1100
    HONDATA S300 w/ boost
    ASKING 300 obo(PENDING)
    crane cams fireball hi-6 ignition box w/ LX92 coil
    ASKING 250 obo
    ek traction bars
    ASKING 250 obo
    2-26" slicks with rims(tires not mounted)
    ASKING-150 obo
    weapon R catch can setup with lines,fittings etc.
    ASKING 150 obo
    there will be much much more as i start to take this car apart, at this point i havent taken anything off but there will be other items like axles,linkage,wiring harness, 1200cc injectors,sx fuel pump,stainless fuel lines,sir cluster, etc etc. if you are interested in anything listed or not you can contact me at 707-540-4272 thanks -mike
  2. jsteg
    jsteg New Member
    Ill take the S300 if deal doesn't go through.
