hydro clutch problems?
i have bleed my clutch alot of times..my clutch pedal still stays on the ground..changed the fluid..still no clutch..it all started with when i drove it the clutch would stick to the floor.i would pull it up and then it would be good for awhile,,no idea..neeed help
I'd say check the clutch master cylinder to make sure its not leaking and as well as all the line and bleeding valve for leaks. Beyond that I'm not sure of much else that could be a problem. Good luck.
jus start replacing everything and youll run into the culprit and youl have alot of new stuff on your car. but no money
