hydro vs cable
Discussion in 'HYBRID -> ED-EF / DA' started by Bobby17772, Sep 27, 2009.
  1. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    later on down the road when I finally do an LS swap in my hatch I was wondering would it be better to get a cable to hydro conversion or get a cable tranny from an integra and just use that. I'm just wondering if there is a benefit to using one over the other. Any help would be great.
    thank
  2. INJEN78
    INJEN78 HS LEGEND
    i hate the hydro conversions...they are a pain in the ass and have some flaws...
    i would just use a cable trans..they are cheaper than hydro by far
    1 person likes this.
  3. Korax
    Korax New Member
    Western PA
    I like the feel of a cable transmission, but I guess that is just preference. The gearing offered in the hydros would be the reason the convert. Aswell as if you go with a EK9 CTR transmission it is dual syncro. I'm pretty sure that is the only B series tranny that had it. Someone may want to correct me.
  4. INJEN78
    INJEN78 HS LEGEND
    i too like the feel of the cable tranny..you are in control of the clutch not the fluid being in control
  5. Bobby17772
    Enfield, CT
    thanks, I was pretty sure I was going to go with cable but I just wanted a few other opinions
  6. INJEN78
    INJEN78 HS LEGEND
    and cable is good because you have the same ooptions for gearing as you do in hydro..theres the b16 trans,the b17(gsr) and the regular ls
  7. Bobby17772
    Enfield, CT
    I herd that the gsr has the shortest gears and ls has the longest, is that true?
  8. INJEN78
    INJEN78 HS LEGEND
    i think its the b16 then gsr then ls...going from short to long
  9. Bobby17772
    Enfield, CT
    I think the gsr would be better, but hey whatever is easier to find and cheaper lol
  10. INJEN78
    INJEN78 HS LEGEND
    lol there are a ton of ls trannies..i got mine for $125..they go for usually $175-200
  11. Danno
    Danno Junior Member
    I have a '98 Spec ITR tranny, and the hasport cable to hydro conversion. STAY AWAY from it. Its garbage. I'll be converting my car to full hydro this winter.
  12. nolimitlowrider
    nolimitlowrider New Member
    why is the hasport garbage?
    Did you use the new unit that uses the clutch master cylinder?
  13. egb19c
    egb19c New Member
  14. ArtfulDodger
    ArtfulDodger New Member
    Gatineau
    I was hoping I might get some links to go away and do a lot of reading and hopefully learn something. I am considering a 2wd wagon project car as a parts car. It was getting switched from automatic to standard. Not driveable. Comes with hydro-cable converter which I can't imagine using, especially since I don't understand its purpose or benefits yet. Anyone willing to post some links or what keywords I want to use in a search engine would be much appreciated.
    88,4RT
  15. Solomon93
    Solomon93 Member
    I LOVE my short geared J1 Cable transmission!
