I HAVE A 89 CRX. IM TRYING TO FIND OUT WHAT BRAKE SET UP TO USE. I KEEP HEARING THAT A 90-93 INTEGRA BRAKES WILL FIT AS LONG AS I GET THE WHOLE REAR AXLE ASSEM. IF I WERE TO DO THE FRONTS ALSO WHAT ALL WILL I NEED TO SWAP THAT OUT???
For the rears you will need the complete setup out of the integra. I do believe that you will use the dog bone link piece that is towards the front of the car from the original stuff. Im not sure about the front but you might need the whole knuckle assembly and possibly the lower control arms also but dont hold me to it. If you are upgrading from drums you will want a proportioning valve out of the same year integra to make it brake correctly.
