i got a bad shake...
eg6sir
Supa Mod
VIP
ok.. when i'm on the freeway and i'm trying to accelerate it still does, but it shakes like no other.. the whole car.. it does it from 60- 75 mph.. after that it quits.. what could be the problem?? could it be a motor mount?? or are the tire off balance? :shrug2:
What make/model? My 91 accord had a bad lower ball joint and it shook a lot around highway so I never took it over 60 so I dont know if it would smooth out. I am replacing the ball joints tomorrow afternoon and will let you know if it worked. Might be of some help.
i would check the axles first. if you can take them out, check to see if they grind. could be anything from dirt to out of balance wheels.
well.. i am going to be replacing my wheels pretty soon.. so i'll see then.. if it still does it after getting the tires balanced i'll look into checking the axles..
