I was told the best car for my $14k would be a ...
Was just wondering if this first possible then was wondering if there anything better i could do with my $14K to get the fastest car for my $$
and the post name is a misprint, i meant to type b18c5
I think you should get a eg hatch with a good body and good interior for 2500-4000 and then spend 4 getting a b18c or 4500. After that you are left with around 5k to spend. And since this is a NA post you could either work on the top or bottom end first. If you work on top end first i suggest you get valves,springs,retainers,cams, and cam gears installed. Then get a hondata and tune that mother. Or you can buy tires/rims, suspension, then i/h/e for your b18c and then what ever you have left get the retainers, springs, cams, gears and valves and hondata. If you cant afford all that after the rims/tires, suspension and what ever i would save up till you can, buy all the parts at once and then save up a little more for the installation. While your saving back up for the installation you will have fun with your b18c, be pretty fast and you know you have more parts ready to be thrown in there. I think thats better than spending 14k on an ARRRR
