I Need A B16a2 Wiring Harness
Lateral4
I'm looking for a B16a2 wiring harness for my swap. These things are impossible to find.
What swap are you doing?
Originally posted by Lateral4@Apr 16 2003, 12:24 AM
I HAVE SWAPPED A B16A2 OBD1 INTO MY 98 EX CIVIC.
Where did you get a OBD I B16A2,and is it stamped B16A2 or are you calling it that?
I got it from LA, and it's stamped b16a, but it has the hydro trany, I watched the guys pull it out of a front clip.
You need a 94-95 Delsol B16A3 harness,or to modify the one in you car now.A B16A2 99-00 si harness is OBD IIb and won't plug into that motor.If you get lucky you can find someone that has one,but since it is the perfect harness for a vtec B series into a 5th gen it is going to be hard.Most of the places likw Import Auto Salvage and some others won't part the harness'es from their motors.If you need it quickly you can,as I said,modify yours or order the Delsol's from www.hondaautomotiveparts.com
