What kind of pistons and rods would i need to get for the mini me setup with a d15b8 block and d16z6 head? I want to eventually runa turbo setup in it. '92 eg
Vitara Pistons and Supra TT Rods *You have to get the rod Milled unless I'm mistaken, but that setup is what I'm going to do when I boost my swap.
Don't put the new pistons and rods into the car untill you boost it though, If you do the minime swap, change out the pistons and have no turbo your compression will be extremely low and you will LOOSE alot of power.
