I WANT MY A/C
Discussion in 'HYBRID -> EG-EK / DC' started by gser, Nov 20, 2003.
  1. gser
    gser Junior Member
    I know i can use a 95' del sol dohc a/c mount "P54" but is there any other mount i can use, like maybe the p30 or use the 99' si mount. i want to keep the A/C system that on there.
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    the 99Si bracket works also.
  3. gser
    gser Junior Member
    Are you sure? because i dont want to do the swap and find out it doesn't, a lot of people say the only one that works is the p54 from the 95 del sol because it is a b16 with the old compressor setup, and the '99 b16 have the newer ones.
  4. JDMilan
    Boca Raton, FL
    I used an LS one and that isn't supposed to fit either, I don't recommend it since it eventually broke off but if you are having doubts just use the del sol bracket, I always thought that it was identical to the 99Si bracket.
