slammedcivic
Member
after searching and finding some info on how to hook up a 99 gsr motor OBD2 into a 95 civic OBD1... I also found out that even if the IAB isnt hooked up right the p72 obd1 ecu WONT throw any fault CEL codes... SO how does one check to see if they did the wiring for the IAB correctly?
