IACV wire up
Discussion in 'HYBRID -> ED-EF / DA' started by jdm2gen03, Jun 17, 2005.
  1. jdm2gen03
    jdm2gen03 Senior Member
    ok i swaped in a obd-1 b16 into my DA wich is or was obd-0(converted to obd-1 now) so i'm throwin only the IACV code after clearing the other codes and was wondering how everyone that has obd-0 cars wired in there IACV.
  2. Dark91zc
    Dark91zc Senior Member
    Corona,CA
    the iacv might be bad on the b16 :( and the iacv only has 2 wires on the plug. i made my obd-0 to obd-1 ecu umper harness and everything worked with my swap but i am still d-series but my but has the b16a and it is still a 2 wire plug i forget the colors but if you have a ecu umper let me know and i can see if a wire is misplaced other wire go find a iacv at a local unk yard or parts store but i don't think they are cheap :( but good luck
    lance
  3. jdm2gen03
    no the thing is i havent even tried to wire it up. i know there is only 2 wires, jus wondering if there was somewere in the bay that i could wire it to so i dnt have to extend it all the way to the ecu.
  4. Dark91zc
    Corona,CA
    if it does not have the plug for it. look for a blue with yellow and black with yellow. i do thing the year matters but i have a 91 hatch but i hope this helps you
    lance
  5. jdm2gen03
    i have the plug for it wit wires coming off but jus want to know wat it wires to off the old harness..... if it comes down to it i will look at my diagrams but i was lookin for the easy way out
  6. Dark91zc
    Corona,CA
    the colors i said :)
