ignition switch blew a fuse? No dash lights
Speed Box
I had problems starting by civic and replaced alot of parts. Searched and found that ignition switch could be one of the reasons.
Ok I got a new ignition switch from a dealer and the bitch was in the on position when i got it and put it in. I thought that I put it in wrong and started to turn it the other way, then small spark happened.
Now my dash lights don't even go on and car just beeps when the key is in. When you turn the key its as if battery is dead nothing happens. And battery is brand spanking new.
Now I can't even find out if ignition switch will help my car start. I checked all fuses.
