I'm rookie, can someone help
Discussion in 'General Tech and Maintenance' started by mozzandherb, Jun 26, 2005.
  1. mozzandherb
    mozzandherb Senior Member
    O.k I'm gonna buy a Walboro 255 fuel pump, but I don't know which one. I'm swapping an h22 into my 92 Accord, so should I get the walboro for my Accord or for the engine. I know stupid question, so someone can answer right?
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You need the one for your car. One question though, why are you upgrading the fuel pump? Boost? If not, it is kind of a waste of money.
  3. mozzandherb
    I will be adding nitrous soon, would that require an upgraded fuel pump? And would the upgraded fuel pump be for the Accord or the H22, I know you said it's for the car, but why is that? Thanks
  4. xj0hnx
    C.C.TX.
    Because it flows enough for either motor, but you want it to fit in your car. Are you adding a FPR, or bigger injectors, running cooler plugs, what kind of system is it going to be? How big are you going, what other mods are done :)
  5. mozzandherb
    I am adding a FPR, the injectors will be the same, I'm thinking about running cooler plugs and it's going to be a 75 shot zex dry kit. Other mods include over bored throttle body, throttle rotor, cam gears, stage 2 flywheel and clutch, headers, short ram intake, cat back exhaust and aem fuel rail.
  6. xj0hnx
    C.C.TX.
    75 shot, get the pump, get it tuned, and have fun.
  7. mozzandherb
