smooth_criminal
I'm about to swap a 99Ls motor into my 96 civic. Am i going to run into any Imobilizer problems?
Originally posted by radnulb@Mar 9 2004, 01:35 PM
I don't think the 99 LS had an immobilizer.
It is kind of a moot point, however. Your motor/ECU is OBD2B (99-01). You car is OBD2A (96-98). You can save yourself a considerable amount of pain and suffering by buying a 96-98 integra LS ECU and either buying a 96-98 integra engine wire harness or using your stock harness with any applicable connectors changed. No 96-98 cars except the ITR had immobilizers, so with a 96-98 ECU you will definately be in the clear, AND you won't need a conversion harness.
Should be an easy swap. Good luck.
