Injector issue
Discussion in 'General Tech and Maintenance' started by jOnZ, Jul 27, 2008.
  1. jOnZ
    jOnZ JDM jOn
    I'm only getting power to one injector what could be the problem ??
  2. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Broken connection or wire, look for a break or split. Check the connections something could have come loose, do you know which injector isnt working?
  3. jOnZ
    jOnZ JDM jOn
    cylinders 123 are not firing but 4 is getting power. Everything is plugged in I checked the voltage on the injector plugs they read 0 but injector 4 reads like 11.7 its confusing:confused:. Should I try a new wire harness?
  4. jOnZ
    jOnZ JDM jOn
    Bump no one knows what going on or what?
  5. jOnZ
    jOnZ JDM jOn
    Tried a new wire harness still not the problem ..... anyone?
  6. t3t4delsol
    t3t4delsol New Member
    York, Pa
    do you have any buddies with the same motor? if so try using there ecu
  7. jOnZ
    jOnZ JDM jOn
    Not ecu either :confused::confused: wtf? Lol, this is very odd... I'm lost on this one anymore suggestions?
  8. Briansol
    work backwards:
    swap the injectors
    put 2 in 4
    if 4 is still the one not firing, it's not the injectors.
    if its not the injectors, and you swapped the harness already..
    do you have a resistor box for p/h? (you don't mention whats in your car...)
    if that all checks out, check your pinouts on the ecu.
    if those are good, check the grounds.
    if that all looks good, take it to a shop :D
