kristoff2478
Can you use low impedance injectors on OBD1 by leaving the resistor box or is there a trick to it? The reason for this is I have 450cc dsm injectors to put on my B18A1 swap in my dx hatch 89. I would still like to use them if I can they clip right in and the only problem I see is the diameter of the lower part of the injector. I guess I need to know also are these the right injectors [4G63 black tops]?
