Injector Size Chart
Discussion in 'Forced Induction' started by hcivic.com, Feb 5, 2003.
  1. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    ok i hear all to often people that do not know what they are talking about saying you need way to big of a injector for diffrent levels of hp here is a deailed chart that will solve all those problems
    sds
  2. gtpilot
    gtpilot Member
    Here's another way...RC Engineering
    Kirk
  3. pissedoffsol
    i would just like to point out that that is rated for 100% duty cycle- which is bad to be at for more than one pull.
    "Injectors should be sized for 75-85% maximum duty cycle on engines used in constant high power applications "
    so, consider bumping up a size
