Injectors part 2
Discussion in 'General Tech and Maintenance' started by austin20110, Jan 26, 2009.
  1. austin20110
    austin20110 New Member
    Northern Va
    Ok
    so before eg put a stop to the fun in the first injector thread i had a question..
    if there is no voltage restriction it will cause the injectors to work at 100% right..
    When an injector works at 100% what closes it, I though that would fri them.
    just trying to understand injectors a little bit better
  2. eg6sir
    legit question.. as soon as the fighting begins, its done
  3. austin20110
    Northern Va
    Dont ruin my thread losers lol... im trying to learn lol
  4. TurboMirage
    got this from some credible ford source:
    An injector cannot operate "over peak duty cycle". Duty cycle is just a ratio between time injector is closed and open. It cannot go over 100%...as it means that injector is constantly open.
    so i guess it would just flow continuously then?
  5. austin20110
    Northern Va
    So the injectors are controlled by the ecu right?
    And the can open like half way or a quater of the way, or are they always all the way open or all the way closed and the amout of fuel is controlled by maybe the fuel pressure regulator?
  6. TurboMirage
    the FPR just controls the amount of fuel entering the rail, provided by the pump.. keeping a max fuel pressure depending on the vacuum supplied to it.
  7. TurboMirage
  8. austin20110
    Northern Va
    would rep ya but i cant... you guys can start arguing again now
  9. TurboMirage
    me versus OP of other thread.
  10. eg6sir
    rep'd for ya.. and no, you guys cant start arguing again
  11. TurboMirage
  12. austin20110
    Northern Va
    so 1 more question injectors are either all the way open or all the way closed right?
  13. TurboMirage
    yeah, looks like its either on or off. where duty cycle shows how fast they can go on and off.
  14. austin20110
    Northern Va
    thanks turbo.. your awesome
  15. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    Fuel injection = teh sex
