Installing A V-afcii On A 95 Civic Ex Coup With A P28 Ecu
Discussion in 'Civic and del Sol - EG and EK' started by allcity403, Aug 24, 2006.
  1. allcity403
    allcity403 Sal
    lake grove ny
    HEY WHATS UP I WAS HAVING TROUBLE INSTALLING MY VAFC II IN MY 94 CIVIC COUP EX.. BUT THEM I TALKED TO APEXI AND GOT IT VERRY SIMPLE...
    1. THE 2 RED WIRED GO INTO A25 ON UR P28 ECU
    2. THE BLACK AND BROWN WIRES GO TO A26 ON THE ECU
    3. GREEN WIRE GOES TO A21 ON THE ECU
    4. GRAY WIRE GOES TO D11 ON THE ECU
    5. DARK BLUE WIRE GOES TO D6 ON THE ECU BUT FIRST CUT THE WIRE FROM THE FACTORY HARNESS AND WIRE IT TO THE ECU ONLY NOT BACK TO THE FACTORY HARNESS
    6. NOW THE VTEC SELONOID WIRING THE PIN IS A2 BUT FIRST CUT THE WIER IN HALF THE PART COMING FROM THE ECU GETS WIRED TO THE PURPLE WIRE AND THE HALF GOING TO THE SELONOID INTO THE HARNESS GETS WIERD TO THE PINK WIRE.
    7. THE SAME AS THE VTEC SELENOIED BUT THE YELLOW WIRE GETS WIERD TO THE ECU AND THE WHITE WIRE TO THE HARNESS AND THAT IS IN THE PIN NUMBER D17
    YOU DO NOT USE THELITE BLUE WORE OR THE ORANGE WIRE SO TAPE THEM OFF.. I DID MINE IN ABOUT 30 MIN... WORKS GREAT
    GOOD LUCK
    THE PIC IS JUST TO REFRENCE WHERE TH EPIN NUMBERS ARE BUT THIS IS A P28 ECU....
