Installing Upper Ball Joint
Discussion in 'Wheels / Suspension / Tires / Brakes' started by DwnShftPrincess, Jan 20, 2005.
  1. DwnShftPrincess
    DwnShftPrincess Senior Member
    Orangeburg, SC
    Does anyone know how to install the upper ball joint on a 96 civic without the control arm. I have a new ball joint for the control arm so what is the correct way to install it?
  2. lsvteccrx
    lsvteccrx Senior Member
    new york
    good luck. they're one piece
  3. LS4DREK
    LS4DREK Junior Member
    the only seperate ball joints i know of avail are the progress adjustables (junk 3 mo. old mine went bad) dont use em you have to press out your factory upper then use the large jam nut to put it in but otherwise ive never seen a factory availible without the control arm
  4. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    The only way to seperate that kind of ball joints is to drill it out. And even that is not really possible unless you are creative and patient.
