Integ Brakes
Discussion in 'HYBRID -> EG-EK / DC' started by vtecsir1, Feb 15, 2003.
  1. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    im thinking of swapping just the front brakes for now on my 95 cx hb. i didnt see any tech on this but what parts will i need? the front hub assembly, rotors and calipers? what else, will my axles fit ? thanks guys
  2. sprfreek
    sprfreek Junior Member
    everything works fine... if your using stock 13" they won't fit .. minimum size rum that will fit is a 14" .... umm integra rotors....integra calipers... also depends on if your using ABS or not ... integra ABS brakes will go onto a NON-abs car... just take the sensors off ... ... just take the whole arm (if rotors and pads are still good leave them on) it bolts right up ... for the EG anyway
  3. vtecsir1
    Orlando, FL
