integra driving me nuts
300zx kid
just put a new distributor in my wifes 91 integra ang i'm not getting any spark went over the ground wires at thero housing and valve cover any help? please
hey mate i woulda suggest you check that you have your firing order right 1342
open up the rocker cover and have a look at the valve ready for the intake thats your number 1 firing sequnce, then move the rotor it should have a spring feeling and that will tell u what way the rotor is moving then hook the 3 up then the 4th lead then the 2nd lead . the cylinders number 1 cylinder will be the closest to the timing pully
hopefully that helps if not check your coil.
You didn't have the key on when you pulled the dizzy?
Sounds like the coil to.. What codes?
Pull the hazzard and ECU fuse to clear them.
Hope that helps ya.
E
