OK all.. I just dropped a 95 OBD1 GSR engine(with GSR harness) in my integra RS(94 OBD1). I see that the engine plugs on the passanger side of the car have all the wires. The car harness that the engine harness plugs into is missing 3 wires. Do I just put wires in the car harness plugs and run them to the ECU? Do I have to mess with any plugs on the driver's side?
I found this:
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue D6
VTEC Ground Black Chassis Ground
Knock Sensor Red/Blue D3
Evap Purge Power Yellow/Black 12V Power
Evap Purge Solenoid Red A20
Secondary Intake Solenoid (IAB) Pink/Blue A17
so...
VTEC ground - does the GSR harness already ground this?
Can anyone tell me exactly what I have to wire up? Thanks!
I found this:
so...
