Internal distributor oil leak
Discussion in 'Accord' started by stevenpfox, Dec 26, 2008.
  1. stevenpfox
    stevenpfox New Member
    california
    Any one found a source on the internal lip seal on the distributor shat under the bearing?
    Steve
  2. stevenpfox
    california
    96 Accord
  3. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    get a new distributor or just go to the junk yard and pull one off of a distributor, that all should be kind of the same on honda's but get an accord one just in case.......good luck finding a distributor for a honda at a junk yard tho, they go like nothing
  4. 94H_Ex
    94H_Ex Under employed
    Florida
    or.... go to your honda dealer and pay for a new seal... I know for a fact theres the seal on the shaft with in your dizzy if thats what your speaking of the leak source. all you do is go in and be like.. heres this seal.. find it gelrado and I shall kindly pay for it. then leave the dealership, install the part and UREKA! problem fixed.
  5. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    Funny you would ask about this, I just replaced mine to sold a somewhat ambiguous leak I have. I did my timing belt and forgot to silicone the valve cover gasket on round three of getting it all together (it was my first one and I screwed a couple of little things up I had to tear down for). Anyway, there was oil runoff from that, but it also looked like I had a distributor leak. So I pulled the cap and the distributor itself was dry inside, while the it seemed to be leaking between the distributor and head. I got the new seal for $2.73 out of the Honda parts dept, replaced it, and now I need to steam clean the engine and see if between the Hondabond on the valve cover gasket and the new O ring I fixed it.
    But be SURE to take a knife and mark a line across the mounting ear on the head and the distributor body so you know what position it's in before you remove it. if you don't do this, you will probably have to retime your engine (not fun at ALL).
    So, assuming the oil leak is external, then that seal is no big job. If it's the shaft bearing, you probably have to buy a new distributor. I know a guy who had the distributor seal/bearing blow out on the highway in his 93 Special Edition EX, and it blew oil into the cap and killed the ignition obviously. The mechanic had to install a new distributor.
