is db8 b18c possible to use mugen ecu(for eg6)
gtimax
I saw the connector plug is the same and some guys said it is useable but don't know what is the effect.....
I wish to know the fuel injuction ok or not?
will it better than my stock ecu?
will it cause problem for long term use?
thanks a lot!
bad idea
it will run pig rich
you will make less power
it isnt even close to tuned for your engine
you are better off with the stock ECU
if you want to upgrade then get something you can tune to your car hondata/crome/neptune/etc
