Is that normal?
Discussion in 'HYBRID -> EG-EK / DC' started by bistec, Feb 6, 2007.
  1. bistec
    bistec Project EH23
    I have a jdm d15b running on a p28 and the engine makes 220 miles on a full tank. :mellow: Is that normal. Am i running too rich? Should i get a p08? With the z6 it was making at least 250 miles per tank. Thanks.
  2. get_nick
    Washington State
    my z6 gets 320/tank. just run the stock ecu.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the po8 will need a 1 wire o2
  4. bistec
    bistec Project EH23
    I though both o2 sensor can be used with the p08 . Correct me if i'm wrong.
    So is the ecu the problem ?
  5. get_nick
    Washington State
    that's my guess also. check your timing to. also, consider a full tune up to. dizzy cap, rotor, plugs, and wires.
  6. AHHVTEC
    Alabama
    no both cant be used the p28 needs a 4 wire po8 needs a 1 wire
