i just did an h22a swap into a 92' accord coupe..
the accord f22 brings an external coil...h22a is internal....what do i need to wire....i've seen people mention the external internal coil subject but the responses i see are very inconsistent....everyone has a different answer.
i read from two people that your are supposed to cut two of the three wires on the original external coil plug from the accord harness and splice them together...and leave the third wire alone..dont plug it anywhere......well i did that and my car was running fine for about 30 minutes and all the sudden it sounded like it was choking...it kept on studdering until it died and would not turn on anymore. i took a shit and thought my timing was off...i tested the distributor by unplugging #1 spark plug wire and i got no spark #2 no spark (off course i had someone cranking the car.
i took the distributor apart and checked the icm..and i got a short on the # 3 wire....[/B]i think it fried my icm! wtf is this...does this have to do with the splicing of the external coil wires?.....oh yeah if its wrong to wire it like that please tell me if im required to rewire anything on the distributor if im using the f22a wiring.
one more thing...what is the correct way to wire the vtec...am i supposed to ground the black wire or does it go to the ecu?
