ITR distributor..
I just wanted to know if I can use other b-series vtec distributor on my b18c ITR motor? Which ones can I use or do I have to stick with a Type R dizzy?
Is it a swap, or just wondering what your options arwe for replacing the stock distributor?
As long as you remain in the OBD that your harness is, you are good. For example, you can interchange GSR, CTR, B16A distributors, as long as they are all say from a 97 if you are using a 96-99 harness.
Yes, you can. Fuck's sake, SEARCH! I have PERSONALLY posted at LEAST three posts about distributor interchangeability in the past week or so! FUCK!
