Itr Front Shocks & Springs
ngq
Member
I have jdm sir front shocks & springs on my 96 civic ex coupe,my buddy gave
me jdm itr ft shocks & spg. if i install them could i expect better road handeling?
Would they fit,are taller or shorter?
the itr shocks and springs are stiffer as a package, as for handling improvments, u have to take it as a whole, it will be slightly stiffer up front, but the rear will remain the same (softer), in other words even more understeer. they springs are slightly shorter on the itr, the shocks are roughly the same length. and yes they fit, the rear is wheer they are different, u need ek9
Thanks chris. The rr setup has civic sir shocks , itr springs & 98spc.23mm itr
sway bar.(i try to stick to original equipment all the time)
