SPEEDFREAK0920
the swap that im getting includes:- Motor
- LSD Hydraulic Tranny (S80)
- ECU (P73)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
but no axles....do i need to use itr axles? or shouldn't i be able to use any 96-97 integra axles? that's what year the engine is. do i need anything else? thanx again
- ECU (P73)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
